Hi there... I know this info is probably around this site, but the site is so huge and honestly aimed for a pro-level above me.
What I am looking for is a simple application that has a GUI that will allow me to copy a mp4 video to a new mp4 video but let me select a external audio file to replace the existing audio.
Basically I like to record game footage (yes another one!). The app I use saved as a mp4 as well as wav files one for game sounds and one for mic input. I then edit that in audacity to mix the two into a single file. Now I want to add that file to the recorded mp4 with out rencoding. (at least on the video, I do not mind if it encodes a wav, or if it inserts a mp3 or w/e.)
Anyway, If you know of a application that uses a GUI that can do this I would be very happy. Thanks you.
No idea. I thought everyone these days did custom installs to keep from getting crap they don't want. Uninstall it?
Edit: It seems harmless enough. I don't know if it's required for MP4Box to work properly. -
I use mymp4boxgui...but it's a bit buggy. Or yamb but I think the interface is a bit confusing and also buggy.
I would like a mp4box gui like mkvmergegui.
How to Replace The Audio File on MP4 with ffmpeg?
By morsh in forum Newbie / General discussionsReplies: 2Last Post: 29th Sep 2014, 08:46 -
Need to replace the current AVI app I use to select/join scenes
By elcoyoteloco in forum EditingReplies: 2Last Post: 24th Jan 2012, 00:18 -
QAM-CrossPlatform IDE for GUI app
By appexpert in forum ProgrammingReplies: 2Last Post: 29th Oct 2011, 12:17 -
ez app to clip AVC MP4 file?
By nonexistent_entity in forum Newbie / General discussionsReplies: 1Last Post: 12th Sep 2011, 12:22 -
How do I replace audio track on Mp4?
By unwired in forum EditingReplies: 3Last Post: 24th Jul 2011, 15:53
